mtldesigns Posted March 21, 2023 Share Posted March 21, 2023 How do I correct this? I have a foundation, roof, model is almost done... but when I do a daylight camera view of the enclosed outdoor kitchen, I get a green glow at the base. This room is mostly enclosed so for grass to be reflecting onto this, to me is impossible. No where else on this slab house, just right here I get the glow. Link to comment Share on other sites More sharing options...
Solution Designers_Ink Posted March 21, 2023 Solution Share Posted March 21, 2023 Turn your sunlight down to about 300 and see if that fixes it. 1 Link to comment Share on other sites More sharing options...
DanDeBroeck Posted March 21, 2023 Share Posted March 21, 2023 Hi Michael, If you are able to share the plan that would be very helpful in tracking down the issue. I was able to reproduce a similar behavior by creating an outdoor room with the slab room type and a slab foundation. Adding a floor finish layer with a texture eliminated the light bleed in my scenario. Without the plan I can't say for sure this will resolve your issue but it might be something to try. Link to comment Share on other sites More sharing options...
mtldesigns Posted March 21, 2023 Author Share Posted March 21, 2023 19 minutes ago, DanDeBroeck said: share the plan Here you go Dan. I tried the changing the room type also, and it didn't seem to work. Its that grass, for some reason it bleads through all around, but with each pass it fades.. except here. That was 4500 samples. Night camera works great! This is a very stripped down version to get it to zip. I still need to work the ceiling in the main house, that shouldn't be the issue.. should it? 52 minutes ago, Designers_Ink said: sunlight down to about 300 I did this to.. was my first thought also. GRIMES BARN HOME WITH GLOW.zip Link to comment Share on other sites More sharing options...
mtldesigns Posted March 21, 2023 Author Share Posted March 21, 2023 1 hour ago, Designers_Ink said: sunlight down to about 300 Jeff, I take my earlier comment back. The first time I changed the suns intensity "adjust sunlight" in the camera setting.. that didn't work. However I just changed the Daytime Backdrop Intensity via the Rendering Tech Options.. that did work! Thanks man... Link to comment Share on other sites More sharing options...
DanDeBroeck Posted March 21, 2023 Share Posted March 21, 2023 Thank you for providing the plan. I do see some light bleed from the backdrop which may be mitigated by reducing the intensity. I found adding a 1/8" thick floor finish layer with a texture eliminated a great majority of the light bleed in that room without having to modify the backdrop intensity. Link to comment Share on other sites More sharing options...
mtldesigns Posted March 21, 2023 Author Share Posted March 21, 2023 8 minutes ago, DanDeBroeck said: 1/8" thick floor finish Good to know Dan. Most of this house has stained concrete floors, and I added 1/16" to that... maybe that's why I didn't have any glow inside? Link to comment Share on other sites More sharing options...
DanDeBroeck Posted March 22, 2023 Share Posted March 22, 2023 The floor finish layer you've added to the other rooms does appear to be eliminating some potential light bleed. Thank you for bringing this issue to our attention, we will look into it. Link to comment Share on other sites More sharing options...
