JKEdmo Posted March 17, 2023 Share Posted March 17, 2023 Good afternoon, I started using the ceiling soffit tool for the first time and have a few questions. Is it only limited to simple box and corner shapes? (I was a little surprised you cannot use the break tool and also boolean Add / subtract tools to create more complex soffits). How do people create more complex ceiling soffits? Thanks again, Jim Link to comment Share on other sites More sharing options...
Solution DBCooper Posted March 18, 2023 Solution Share Posted March 18, 2023 Cabinet soffits are pretty limited, but still useful. One thing that they can do that other things can't is automatically match the slope of a vaulted ceiling. They can also have moldings attached (but not when sloped!). If you need more control over the shape, you could use a 3D solid. If you only need to shape it in plan view but still need a molding, you could use a counter top. Another thing you might want to look at is the "trey ceiling" tool. Depending on what you are trying to do, this might do the job much better. Link to comment Share on other sites More sharing options...
JKEdmo Posted March 18, 2023 Author Share Posted March 18, 2023 14 hours ago, DBCooper said: Cabinet soffits are pretty limited, but still useful. Thanks DB. I appreciate your quick response. Jim Link to comment Share on other sites More sharing options...
