Steve_Nyhof Posted March 7, 2023 Share Posted March 7, 2023 Make sure to read the thread above to understand the context of the problem and a few solutions. Link to comment Share on other sites More sharing options...
DeLayDesign Posted March 7, 2023 Share Posted March 7, 2023 Yeah; it's a bit annoying, but one way I've overcome it is to use the soffit tool and add a very thin (1/16") molding to the sides the same height as the beam. You can tell the beam to sit under ceiling and it will automatically slope following the ceiling. The moldings allows you to then have two different variations of the material traveling in the correct direction if you need. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted March 7, 2023 Author Share Posted March 7, 2023 9 hours ago, DeLayDesign said: Yeah; it's a bit annoying, but one way I've overcome it is to use the soffit tool and add a very thin (1/16") molding to the sides the same height as the beam. You can tell the beam to sit under ceiling and it will automatically slope following the ceiling. The moldings allows you to then have two different variations of the material traveling in the correct direction if you need. This is brilliant! I'm going to mess with this now. I know that we can add moldings to the soffit. I just did not think about this. Thank you Link to comment Share on other sites More sharing options...
robdyck Posted March 7, 2023 Share Posted March 7, 2023 10 hours ago, DeLayDesign said: use the soffit tool and add a very thin (1/16") molding to the sides the same height as the beam. This would also be a very simple way to adjust into a boxed beam with the sides extending slightly lower. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted March 7, 2023 Author Share Posted March 7, 2023 I was so hopeful, but when you angle the soffit to fit the cathedral ceiling, it removes the molding... Link to comment Share on other sites More sharing options...
DeLayDesign Posted March 10, 2023 Share Posted March 10, 2023 Dang! Sorry @stevenyhofmaybe @ChiefArchitectcan weight on this. Seems like an issue that needs resolving Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted March 10, 2023 Author Share Posted March 10, 2023 56 minutes ago, DeLayDesign said: Dang! Sorry @stevenyhofmaybe @ChiefArchitectcan weight on this. Seems like an issue that needs resolving Yeah, I found a number of ways to do what I wanted in the thread this is connected to, but I think they need to be able to paint wood grain on a soffit. Link to comment Share on other sites More sharing options...
