Evolution Posted February 6, 2015 Share Posted February 6, 2015 I am sure IT IS SOMETHING I'VE DONE (and if I knew what it was-I would un-do it), however, after searching hours last night, and a few this AM, I am unable to figure out WHAT I DID or how? But now when I place a camera, or select it to move/relocate the (assume) snap / or drag angles appear as a sun burst araound it. Also, shows up when I select a wall to drag or move. I REALLY-REALLY have done the word search here, and the help KB's, User manual, I just haven't found exactly what it is or how to turn it on/off! BELIEVE ME, I have exhausted the research attempting to find the answer, it may be I'm just not entering the correct word for what I'm searching for. Link to comment Share on other sites More sharing options...
ArthurDent Posted February 6, 2015 Share Posted February 6, 2015 Turn off "display angle snap grid" in your preferences under snap properties. 1 Link to comment Share on other sites More sharing options...
dshall Posted February 6, 2015 Share Posted February 6, 2015 Turn off "display angle snap grid" in your preferences under snap properties. Arthur, you answered his question in less than 5 minutes..... what took you so long? Link to comment Share on other sites More sharing options...
ArthurDent Posted February 6, 2015 Share Posted February 6, 2015 I knew the answer because I've been bit by that one before. Link to comment Share on other sites More sharing options...
Solution Evolution Posted February 6, 2015 Author Solution Share Posted February 6, 2015 Turn off "display angle snap grid" in your preferences under snap properties. Thanks Arthur. Seriously though, key word search snap and snap grid brought me no where previously. I even used "snap grid" "camera angle snap" etc., and stil no help. So I went to each Parent tool and FINALLY under view, down near the bottom, there was THAT little BOOGER child tool "angle snap grid" but no snap properties. Of course the real answer is CRAM and CRAM and CRAM some more and if you can REMEMBER all the stuff you've CRAMMED you might be able to find the things you're looking for. Thanks again! Now on to the next issue and thread to post. Link to comment Share on other sites More sharing options...
ArthurDent Posted February 6, 2015 Share Posted February 6, 2015 It's also in the preferences (and I did not even realize it was in the menu). Link to comment Share on other sites More sharing options...
