Stairs clipping
pjames
Go to solution Solved by tundra_dweller,
1 hour ago, pjames said:
If I adjust the bottom height to remove this then the first flight is raised as well. Any ideas?
Stair sections connect.  You can Alt+click to adjust just the one set, if you want.
(Also there is a matching wood material for the plank flooring.  Not sure if you know this or you like the look of plank on your steps.
I personally use the wood and not the plank on stairs so that there's a better distinction between floors and stairs.)
