.dwg file not displaying properly
Maggie331
Go to solution Solved by para-CAD,
I was sent my drawing in a .dwg file. When I attempt to import the file, it all opens on 1 page, so each floor is stacked on top of the other. How do I import the file to see each page/floor of the drawing?
Maggie
Chief Architect user X14 version
Next time you have to import a dwg, I would import it into a plan file, not a layout.  While you are in the "importing drawing assistant", you can select which layers you want to import and you can even map them to whatever Chief layers you want to using the "advanced layer mapping".  You can find lots of info on this by using the help button in the assistant.
Thank you
