Layout Print Defaults
Jones_Drafting
In X6, is there an easy way, after having populated the layout from my various views with their associated layer attributes(including colors), to convert all views contained in layout to black and white?...(not greyscale)
I like the various colors as easy reference, but do not like the greyscale print results.
Thanks!
What if you change from color to black and white in the original view, not in Layout?
This is the way I normally do it, although the other way around. I typically send in color and then print to pdf as gray scale so that I can get the material hatch patterns in a soft grey color.
