Missing Attic Wall
Rander91
Go to solution Solved by Alaskan_Son,
  • Solution
In this particular instance, it looks like you need to drag out an extra Attic Wall section on Floor 2 and set to Roof Cuts Wall at Bottom (Roof tab):
NOTE:  It actually requires 2 attic walls because of the intersection with the pantry walls but you should be able to drag out a single wall.  The break should occur automatically.  Just make sure both walls have the correct settings.
NOTE:  It actually requires 2 attic walls because of the intersection with the pantry walls but you should be able to drag out a single wall.  The break should occur automatically.  Just make sure both walls are set correctly.
Thank you!
  • 1 year later...
