builtright3 Posted January 20, 2023 Share Posted January 20, 2023 Does anyone know if there is a way to change the text font globaly throught the program without haveing to go through every annotation set? Link to comment Share on other sites More sharing options...
MarckusW Posted January 21, 2023 Share Posted January 21, 2023 Joe, start at edit on the main bar, pull down and go to preferences, at the top you will see appearance, drop down the menu and you will find font. This is a good place to start. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted January 21, 2023 Share Posted January 21, 2023 Assuming that you are using "text styles" (instead of custom text) everywhere, then you should be able to change most of them all at once. Just go into your text style defaults and then you can group select all of the text styles to change the font in one step. Then do the same for all of your rich text defaults (since they can't use text styles). Link to comment Share on other sites More sharing options...
builtright3 Posted January 21, 2023 Author Share Posted January 21, 2023 On 1/21/2023 at 5:54 AM, DBCooper said: Assuming that you are using "text styles" (instead of custom text) everywhere, then you should be able to change most of them all at once. Just go into your text style defaults and then you can group select all of the text styles to change the font in one step. Then do the same for all of your rich text defaults (since they can't use text styles). Expand Thank you that was a big help becasue I didnt know you could group select Link to comment Share on other sites More sharing options...
builtright3 Posted January 21, 2023 Author Share Posted January 21, 2023 On 1/21/2023 at 3:37 AM, MarckusW said: Joe, start at edit on the main bar, pull down and go to preferences, at the top you will see appearance, drop down the menu and you will find font. This is a good place to start. Expand Thanks for making me aware of the font under the preferences. It doesnt do anything globally but I dont want to leave something out. I want the materials list ot be the same also. Link to comment Share on other sites More sharing options...
