Wall Intersections
wftingen
When I have to intersect an interior wall with an exterior wall, how do I connect them and remove then material showing on the end of the connecting wall?
You'll see that it is showing osb, house wrap, and siding on this wall that is intersecting with an interior wall.
Thank you
3 minutes ago, Garybills said:
Select the interior wall and then select the edit wall layer intersections. I know it’s available in Premiere x12 through x14 but not in Home Designer Pro.I see you have X14 and you can select which ever wall you need to adjust
