Gas Cooktop- Make-Up Air Requirements & Design
cajunland
This subject applies to plan design examples applying Code for kitchen remodel.
Seems like gas appliances and ventilation are in the news a lot lately.
I understand IRC requires a dedicated makeup-air system for range hoods that are larger than 400 cfm
I am installing new Thermador 36" gas cooktop vented upwards and room is on a slab foundation. Minimum 400 cfm for vent hood fan.
Best approach I can think of is use CA's HVAC and MEP catalogues to create Layout with the following:
-ceiling register, spiral ducting, motorized damper and exterior wall vent cover in soffit for make-up air intake.
To hot and humid here for roof intake, I think.
I found this example at Fine Homebuilding / article by M. Holiday- How to Provide Makeup Air for Range Hoods, DECEMBER 2012/JANUARY 2013.
Flex duct is illegal now.
If I have missed this type example/detail for this specific subject on the Forums or in sample plans on CA web kindly reply.
OK
That a good reference site CA advertises in.
I'll check there too.
This issue has significance to me as I have learned at great expense about HVAC venting and technical issues for my air conditioning systems.
5 ton system had to be replaced due to insufficient are return size and moisture issues. Only 4 years old.
From the IRC commentary regarding this,
 It is becoming more common for residential kitchens to
resemble commercial kitchens, both aesthetically and
functionally. As a result, much larger-capacity range
hoods are being installed which aggravates the
already existing problem of a lack of adequate makeup
air for all exhaust systems in the dwelling. Homes typically
suffer multiple ills because of indoor negative
pressures caused by an imbalance of exhaust air to
makeup air. The problem is that air is being removed
from the dwelling faster than air can leak back into the
building by infiltration through cracks, gaps and flaws
in the thermal envelope/air barrier. The typical home
relies solely on infiltration for makeup air, and homes
are being built much more airtight than in the past.
Compounding this issue is the trend for much larger
exhaust fans. The resulting pressure imbalance problem
is a very real safety concern.
