JKEdmo Posted January 5, 2023 Share Posted January 5, 2023 Good morning, I'm working on an as-built of an older house with masonry exterior walls. My gable end walls currently stop at the underside of the roof rafters, which I think is normal. Is there a setting to have these walls continue to end at the underside of roof deck above? Here's a screenshot of the offending gaps: Thanks again, Jim Link to comment Share on other sites More sharing options...
joey_martin Posted January 5, 2023 Share Posted January 5, 2023 Check the setting of the sub-fascia. If it's larger than the fascia it will push the wall down accordingly. Link to comment Share on other sites More sharing options...
JKEdmo Posted January 5, 2023 Author Share Posted January 5, 2023 1 hour ago, joey_martin said: Check the setting of the sub-fascia. If it's larger than the fascia it will push the wall down accordingly. Thanks Joey. I checked that and it does not seem to be the case. I uploaded the plan. I did notice I can drag the walls tops to infill and produce the frieze. I guess that's a good workaround, but maybe not best practice. TEST.plan Jim Link to comment Share on other sites More sharing options...
JKEdmo Posted January 5, 2023 Author Share Posted January 5, 2023 Thanks Eric. I'll do just that. BTW, I appreciate that the community takes time out to help. It's a very nice bonus to the software. Jim Link to comment Share on other sites More sharing options...
