JKEdmo Posted January 2, 2023 Share Posted January 2, 2023 Are Chief wall plan hatch directions always based on the direction of the wall? See masonry wall snapshot below. Is there an option to set the hatch direction so it is fixed "globally" in one direction like hand-drafting? P.S. I first thought that Chief hatch directions might be always object based, but I did a little test with a hatched polyline box. The hatch patterns there seem to behave "globally". Thank you, Jim Link to comment Share on other sites More sharing options...
Kbird1 Posted January 2, 2023 Share Posted January 2, 2023 1 hour ago, JKEdmo said: Is there an option to set the hatch direction so it is fixed "globally" in one direction like hand-drafting? I don't think so but if you are using the Wall Hatching tool? you can open the Hatch ( Tab In after selecting wall ) and switch it from say Hatch angle 2 to Hatch angle Link to comment Share on other sites More sharing options...
