OrinCrowder Posted December 19, 2022 Share Posted December 19, 2022 Can't get these exterior walls to come up to the roof. Tried all the wall / roof options and tried deleting and rebuilding the attic layer. Same thing happened with a full shed roof rather than this version that creates a gable roof over the second story porch area (that is clearly not completely worked out). Any help is much appreciated. Thanks. Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted December 20, 2022 Solution Share Posted December 20, 2022 2 hours ago, solver said: Edit>Reset to Defaults Then Try Ballooning the Walls Up in their Structure Tabs. * you do have Auto Attic Walls Enabled right? > Press Alt-Q (general Wall Defaults shortcut) and see if it checked. Mick. Link to comment Share on other sites More sharing options...
OrinCrowder Posted December 20, 2022 Author Share Posted December 20, 2022 Thank you. Much appreciated. Ballooning the walls fixed it but now I know to also try resetting to defaults for other issues. And, yes, attic walls auto rebuild was on. Link to comment Share on other sites More sharing options...
