ACADuser Posted December 16, 2022 Share Posted December 16, 2022 On the 1st floor I want to use "Dens-Glass" in place of Drywall for room schedule. How do I add that to the plan or rename Green board so mu schedule display correctly? Thanks Link to comment Share on other sites More sharing options...
TeaTime Posted December 16, 2022 Share Posted December 16, 2022 30 minutes ago, ACADuser said: On the 1st floor I want to use "Dens-Glass" in place of Drywall for room schedule. How do I add that to the plan or rename Green board so mu schedule display correctly? The fastest way is not to swap Drywall, just redefine it. Under 3D> Materials> Plan Materials, locate Drywall, Edit it and change it's name, color, Materials List properties if it needs to be calculated differently, etc. Then all Drywall will be Dens-glass. If you need to mix and match for Walls v Ceiling or different rooms, then you'd need to specifically redefine your wall layers. Link to comment Share on other sites More sharing options...
TeaTime Posted December 16, 2022 Share Posted December 16, 2022 Oh. 39 minutes ago, ACADuser said: On the 1st floor... if you need that level of specificity you'd need different wall types for Floor 1, swap their Drywall layer with a new Dens-Glass material. Link to comment Share on other sites More sharing options...
ACADuser Posted December 16, 2022 Author Share Posted December 16, 2022 Thanks for the info. I need drywall on the other 2 floors so I will rename backer board, I think. Link to comment Share on other sites More sharing options...
TeaTime Posted December 16, 2022 Share Posted December 16, 2022 X14 introduced a cool way to copy materials using the Material Painter that might make quick work of this sort of thing in the future, too. In a 3D view choose the Material Eyedropper and click on Drywall, and at the bottom there's a new "Copy Selected Material" option. It'll open a Drywall_2 material, name it, edit it, etc., then hit OK, change the painting Scope to "Floor" and paint the Drywall. Link to comment Share on other sites More sharing options...
ACADuser Posted December 17, 2022 Author Share Posted December 17, 2022 That was the trick I was looking for. Thanks I now have a new Dens-Glass material & made some new wall types. AmberBock time here. Link to comment Share on other sites More sharing options...
