Makeityou Posted December 15, 2022 Share Posted December 15, 2022 I am trying to create a zig zag and diamond pattern in black and white 8 x 8 hexagon tiles. I managed to get a daisy pattern with screen capture but cannot find high resolution photos of the other two nor did I see a way to make it in substance player. I've watched pretty much any training video I thought might help to no avail. I've included a photo of the diamond pattern I'm trying to replicate. Any help would be appreciated. Thanks in advance. diamond pattern.jfif Link to comment Share on other sites More sharing options...
SusanC Posted December 17, 2022 Share Posted December 17, 2022 Can you post the photo of the pattern you are trying to create in a .jpg format or a .png? I don't seem to be able to open a .jfif. Thanks! Link to comment Share on other sites More sharing options...
Kbird1 Posted December 17, 2022 Share Posted December 17, 2022 37 minutes ago, SusanC said: I don't seem to be able to open a .jfif. the Windows Photo App should open a .jfif, it's a jpeg or similar...... this is it....... Link to comment Share on other sites More sharing options...
SusanC Posted December 17, 2022 Share Posted December 17, 2022 Thanks Mick for the tip on how to open the .jfif. I did a Google search and found that .jfif photo on The Tile Shop website. There is another photo with it, posted by a designer who used that tile layout in real life, and because the photo was shot straight on, you can take a screen shot of a portion of the tile design to import into Chief to create a material. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 17, 2022 Share Posted December 17, 2022 15 hours ago, SusanC said: I did a Google search and found that .jfif photo No problem and thanks for the Tip on using Google search on Images, I had forgotten that was an Option , might be handy for when I'm sent an Inspo Image and the Client has no clue where they got it M. Link to comment Share on other sites More sharing options...
SusanC Posted December 17, 2022 Share Posted December 17, 2022 You're welcome! I have good luck finding images that way. Link to comment Share on other sites More sharing options...
Makeityou Posted January 10, 2023 Author Share Posted January 10, 2023 Thanks for the responses. I did finally find photos and got them copied. It's not perfect, but it worked enough to get the point across. Unfortunately, there was a random dot I the photo I couldn't work around. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted January 10, 2023 Share Posted January 10, 2023 39 minutes ago, Makeityou said: was a random dot I the photo I couldn't work around You should be able to open the Image in Paint and take a small selection of the black tile, copy it, paste it back into the pic, and drag it over the White Dot and resave it. If the size of the Hex is supposed to be smaller ? make the texture size smaller on the Texture tab in Chief's Material DBX. Link to comment Share on other sites More sharing options...
