DRyeHD Posted December 14, 2022 Share Posted December 14, 2022 Is there a way to use the Wall Type DBX for this L Block foundation (or some other way) so the slab displays to the inside edge of the L Block. The "L Block" is created as a pony wall (see Wall Type DBX in screenshot) but I can't figure out how to manipulate the slab. Any ideas would be appreciated. Link to comment Share on other sites More sharing options...
Solution joey_martin Posted December 14, 2022 Solution Share Posted December 14, 2022 Go to the foundation defaults and check this box so that the slab sits against the 4" top part of the pony wall.. 1 1 Link to comment Share on other sites More sharing options...
DRyeHD Posted December 14, 2022 Author Share Posted December 14, 2022 14 minutes ago, joey_martin said: Go to the foundation defaults and check this box so that the slab sits against the 4" top part of the pony wall.. Thanks so much! I hoped it was something easy that I was overlooking. Link to comment Share on other sites More sharing options...
