SHCanada2 Posted November 27, 2022 Share Posted November 27, 2022 I am looking for a CAD block for a heating element in a duct for a makeup air unit. I found a nice symbol, wall radiator towel warmer. but its 2d block is a top view. is there a method to convert the symbol's other plane into a 2D CAD block. i.e. I want the picture below as a CAD block thanks Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 27, 2022 Share Posted November 27, 2022 Rotate the symbol either through the Symbol Specification dialog or in an elevation view. You just need to make sure to either: Manually click Generate Block in the Symbol Specification dialog (2D Block tab) Check Auto Generate (same location as mentioned above) Click Yes when you get the "Do you want to regenerate the 2D plan view symbol..." popup after rotating in elevation You also may or may not want to adjust the Smoothing Angle (General tab) and/or Fill settings (2D Block tab) depending on the object. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 27, 2022 Share Posted November 27, 2022 You can also optionally just take an elevation view, click CAD Detail From View, and then group select and Block the resulting linework. Link to comment Share on other sites More sharing options...
SHCanada2 Posted November 27, 2022 Author Share Posted November 27, 2022 perfect, I forgot about the cad Detail from view merci Link to comment Share on other sites More sharing options...
SHCanada2 Posted November 27, 2022 Author Share Posted November 27, 2022 35 minutes ago, Alaskan_Son said: Rotate the symbol either through the Symbol Specification dialog or in an elevation view. looks like the key here is to ensure it is flat on the x,y plane . this works: 26.11.2022_16.57.59_REC.mp4 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 27, 2022 Share Posted November 27, 2022 6 minutes ago, SHCanada2 said: looks like the key here is to ensure it is flat on the x,y plane Yes. The CAD Block is generated according to the Plan view (as viewed from the top). For your example that would likely mean dropping the object into the plan straight out of the library, clicking Open Symbol, selecting X Axis, and clicking either Rotate+ or Rotate- (depending on which side you wanted to see). Link to comment Share on other sites More sharing options...
