RobUSMC Posted November 25, 2022 Share Posted November 25, 2022 Has anyone seen a plain double stacked shaker style door in the library. We build all our own in house and with tall pantry cabinets the lower area doors are usually a single shaker door with a center mid rail. I found one close but it has an inside beaded profile and wont match the other doors. I know I can split a door horizontally but I need them to open as one and be a single area behind the door for rollouts or other. See attached. Thanks Link to comment Share on other sites More sharing options...
MarkMc Posted November 25, 2022 Share Posted November 25, 2022 On 11/25/2022 at 7:20 PM, RobUSMC said: plain double stacked shaker style door Expand what width rail and stile do you need? Link to comment Share on other sites More sharing options...
MarkMc Posted November 25, 2022 Share Posted November 25, 2022 On 11/25/2022 at 7:20 PM, RobUSMC said: plain double stacked shaker style door Expand here's a 3" dble shaker 3 in.calibzFetching info... 1 Link to comment Share on other sites More sharing options...
RobUSMC Posted November 25, 2022 Author Share Posted November 25, 2022 Thank you so much Mark. Can I adjust the rail width. The default "framed" door looks to have a little narrower rails probably 2.5" Link to comment Share on other sites More sharing options...
MarkMc Posted November 25, 2022 Share Posted November 25, 2022 On 11/25/2022 at 10:40 PM, RobUSMC said: probably 2.5 Expand attached DBL shaker 2-5.calibzFetching info... 1 Link to comment Share on other sites More sharing options...
MarkMc Posted November 26, 2022 Share Posted November 26, 2022 On 11/25/2022 at 10:40 PM, RobUSMC said: Can I adjust the rail width. Expand I should have thought of this before. Here is a stripped down version of the plan I used to make these. (in X13, the complete version was posted here sometime in the past, and a newer version more recently) Box Construction tab, change separation to suit. Then front/side/back tab_ equalize if both top and bottom to be the same, else adjust sizes to suit. Then convert to symbol- change materials so each is set to use default (rename rails and panels to suit) Set stretch planes ---Look at previous symbols for settings for stretch planes. DBL door plan.zipFetching info... Link to comment Share on other sites More sharing options...
SusanC Posted November 26, 2022 Share Posted November 26, 2022 Hi Rob, I often run into the exact issues you are describing and Mark is definitely the expert on cabinets! I recently put a suggestion on the Suggestions forum requesting the ability to customize cabinet doors more easily through the cabinet dialog box instead of always having to do a work around. If you'd like to chime in on that request, it can be found by typing into the search bar "Custom Cabinet Door Styles" (be sure to use the quotation marks). The more users who request a new feature, the better the chance Chief will produce it. Thanks! Susan Link to comment Share on other sites More sharing options...
RobUSMC Posted November 27, 2022 Author Share Posted November 27, 2022 On 11/26/2022 at 4:32 PM, SusanC said: Hi Rob, I often run into the exact issues you are describing and Mark is definitely the expert on cabinets! I recently put a suggestion on the Suggestions forum requesting the ability to customize cabinet doors more easily through the cabinet dialog box instead of always having to do a work around. If you'd like to chime in on that request, it can be found by typing into the search bar "Custom Cabinet Door Styles" (be sure to use the quotation marks). The more users who request a new feature, the better the chance Chief will produce it. Thanks! Susan Expand I will do that now Susan. Thanks 1 Link to comment Share on other sites More sharing options...
RobUSMC Posted November 27, 2022 Author Share Posted November 27, 2022 On 11/25/2022 at 11:26 PM, MarkMc said: attached DBL shaker 2-5.calibz 7.81 kB · 5 downloads Expand Mark, That was perfect. Thank you so very much. If I owe you anything please let me know. 1 Link to comment Share on other sites More sharing options...
