JKEdmo Posted October 6, 2022 Share Posted October 6, 2022 Hello, In my beginner's quest to better understand things, I was curious about the wall polyline Chief produces, notably the highlighted message, "Polyline produced by 3D wall editor." What is this object's purpose / function? Thanks again, Jim Link to comment Share on other sites More sharing options...
JKEdmo Posted October 6, 2022 Author Share Posted October 6, 2022 28 minutes ago, solver said: Do those 2 bolded words give you a hint? Yes, a little bit. Is the polyline something normally produced by Chief and to be expected, or only when I manually tweak a wall? For example, override the wall heights. Jim Link to comment Share on other sites More sharing options...
JKEdmo Posted October 6, 2022 Author Share Posted October 6, 2022 1 minute ago, solver said: And you should not be tweaking a wall by overriding what Chief builds -- wall top and bottom, unless there is no other way, which is rare. Doing so stops Chief from managing the wall and mostly creates more problems than it solves. Suggest asking here next time you feel the need to do some wall tweaking. Got it. Thanks for the quick response and insight. Jim Link to comment Share on other sites More sharing options...
DBCooper Posted October 7, 2022 Share Posted October 7, 2022 Normally, you shouldn't change the wall top or bottom, you should adjust the room floor or ceiling instead. One time you might need to edit the wall poly is when you need to build a stepped foundation. This article has some of the basics: https://www.chiefarchitect.com/support/article/KB-00579/controlling-wall-floor-and-ceiling-heights.html Link to comment Share on other sites More sharing options...
