shawnfndr Posted October 2, 2022 Share Posted October 2, 2022 I’m sure the answer is very simple, but I’m a simpler man. I imported a pdf to trace and add measurements. All 6 pages imported to one page. How do I move them into a separate set of drawings? I’ve tried a few things, but my novice is showing. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 2, 2022 Share Posted October 2, 2022 you have to import a page at a time Link to comment Share on other sites More sharing options...
shawnfndr Posted October 2, 2022 Author Share Posted October 2, 2022 Thanks sir. Good practice. I was hoping there was a way to copy and paste each after highlighting, but I’m only able to do so as floor elevations on a new plan, so I can’t get all pages into a new plan. Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 3, 2022 Share Posted October 3, 2022 On 10/2/2022 at 8:56 AM, shawnfndr said: Thanks sir. Good practice. I was hoping there was a way to copy and paste each after highlighting, but I’m only able to do so as floor elevations on a new plan, so I can’t get all pages into a new plan. Best practice for my own workflow is to import a pdf and simply change the page in the Open Object Dialog box as needded. If you want all pages you can do that as well and simply drag them around the background drawing sheet. You can copy/paste a pdf then drag the center handle to create a copy of the PDF then open and change the page for that copy Link to comment Share on other sites More sharing options...
