GeneDavis Posted September 22, 2022 Share Posted September 22, 2022 I did a search and found some posts from pre-X14. There seemed to be no tools for drag and drop a CAD detail from plan A to plan B, other than to create a new one in B, open the one in A, marquee-select all or whatever you want, then paste it into the new one opened in B. Is this still the deal, or did we get something new? I want to create some new better template files and want a rich set of CAD detail in each. Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 22, 2022 Share Posted September 22, 2022 19 minutes ago, GeneDavis said: I did a search and found some posts from pre-X14. There seemed to be no tools for drag and drop a CAD detail from plan A to plan B, other than to create a new one in B, open the one in A, marquee-select all or whatever you want, then paste it into the new one opened in B. Is this still the deal, or did we get something new? I want to create some new better template files and want a rich set of CAD detail in each. If you have a set of CAD details established, it is easier to import your new defaults and saved plan views and macros into the plan that has the CAD details, instead of dropping cad details into a new template Link to comment Share on other sites More sharing options...
