Display Construction Lines on Single Elevation
Crusader103
Go to solution Solved by DBCooper,
I would like to display construction lines on the front elevation to convey the location of ridges in relation to other points. The adverse effect is that they also show up on the rear elevation, where they don't make sense.
Is there a way to display construction lines only on the front but hide them on the rear?
The only thing I thought of was to duplicate the plan, turn that layer off in the other plan, and relink the layout to that plan. But it seems there might be a better way to hide those construction lines in a single elevation that I'm overlooking.
  • Solution
Quote
Why would you copy the plan when you could just copy the layer set?  Each view can use it's own layer set.
    33251
    A_Hasan
    A_Hasan
