3 Drawer Corner Cabinet
Rich_Winsor
Go to solution Solved by Joe_Carrick,
Since there seems to be a lot of discussion about
cabinets here lately I thought I would throw this one
out there also. This little PITA is called a 3 Drawer
Corner Cabinet.
1024911781_CornerCabinetw_Drawers-crop.thumb.jpeg.789d43603d5f472b8db1a19a22885437.jpeg
After wasting a couple of hours (including
watching a Chief video) trying to wring this
out of the Base Cabinet Spec DBX I threw
in the towel and settled for a 5 minute hack
since all I was after was the appearance and
not the functionality. I just stuck a 3D Solid in
the corner and slapped some drawer fronts
from the library onto it.
Just for my edification I'd like to know if this
configuration is doable as a cabinet?
BTW, I've seen this cabinet configuration - but IMO it's way too expensive.  It's easier and far less cost to just use a narrow (about 18" wide) cabinet set at an angle of 45 degrees.
Also be very careful to provide adequate clearance between the drawer fronts and the side of the cabinet so that the drawers can actually be opened without hitting the adjacent cabinet drawers.  Full overlay just won't work.
I typically use a 3/4" spacer panel or extended stile on the sides of adjacent cabinets.
Not to hi-jack my own thread or in any way disparage
Joe, but I did not mark this thread as "Solved". In fact
I hadn't even read the replies yet when it was marked
as Solved. If I didn't then who else has the power to
do so? Just trying to figure what happened and when?
Original Post: 23 hours ago
Joe's response: 20 hours ago
I log in tonight - 22 hours since my last visit
Go to read the new replies and find the thread marked
as solved even though I haven't read the replies yet???
I think this is the point where I invoke the old standby...WTF?
It's bad enough that we have people marking their own posts
as the Solution. Now apparently anybody can mark my posts
as Solved too.
BTW, when I calm down I'll have a play with it Joe.
Hi Joey,
I thought you had marked it "solved".  I had no idea that anyone else could do that.
In fact, the only place I've been able to find that option is in this (Q&A) Forum for my own threads.
Maybe it was one of the CA Moderators.
If not then you must have been "Sleep Browsing" B) unless someone else has your ChiefTalk login info.
