ChiefMango Posted September 2, 2022 Share Posted September 2, 2022 Hi All, I'm working on a simple reflected ceiling plan. I've drawn the suspended ceiling using CAD lines, and now I'm trying to add ceiling lights. When I drop a 2x4 tube light onto the drawing, it's drawing behind the CAD lines. Ive opened both the object and the CAD line and set the former to drawing group 1 (front) and the latter to drawing group 39 (back) and it's still not displaying correctly. The CAD symbol for the light has an opaque fill, so it's not like its an issue of transparency. I'm lost here. Anyone have any suggestions? Thanks in advance for any help Link to comment Share on other sites More sharing options...
Kbird1 Posted September 2, 2022 Share Posted September 2, 2022 Always best to supply at least a Test Sample plan with the Issue, the Forum has a limit of 14mb now , so zip the Plan File while Chief is Closed if needed to get it under the limit. M. Link to comment Share on other sites More sharing options...
Solution rlackore Posted September 2, 2022 Solution Share Posted September 2, 2022 If you're using the Chief core content, the solid fill is turned on for the Tube Lighting>Recessed symbols, but not the Tube Lighting>Surface Mounted symbols. Link to comment Share on other sites More sharing options...
ChiefMango Posted September 2, 2022 Author Share Posted September 2, 2022 5 minutes ago, rlackore said: If you're using the Chief core content, the solid fill is turned on for the Tube Lighting>Recessed symbols, but not the Tube Lighting>Surface Mounted symbols. That's it! Thanks a million! Link to comment Share on other sites More sharing options...
