RobWhite Posted August 28, 2022 Share Posted August 28, 2022 Is there method to bring construction line into the foreground? Construction lines do not have the 'View Draw Order Edit Tools' icon button I am using the construction lines as grid line. I assume that is their purpose I am working in a section camera view and can reasonable achieve the visual of brining the construction lines in the foreground by using the 'View Order Edit Tool icon to push other cad items behind the construction line, but this is not very successful and quite long winded Link to comment Share on other sites More sharing options...
DBCooper Posted August 29, 2022 Share Posted August 29, 2022 It looks like you can control the draw order in plan view but not in an elevation view. You might want to add a +1 to this suggestion: https://chieftalk.chiefarchitect.com/topic/31508-add-drawing-group-to-construction-line-dbx-in-cross-sectionelevation-view/ Link to comment Share on other sites More sharing options...
