SHCanada2 Posted August 27, 2022 Share Posted August 27, 2022 for existing houses, I have the need to show a dimensioned parking stall on an existing survey(brought into CA as a image) which *should be* 10'x20', but sometimes there is not enough existing driveway so sometimes it is 10x19'6 or it is a half trapezoid to match the curb or sidewalk. so i was trying to create a CAD block with dimensions, but that doesnt work as it looks like the dimensions get converted to CAD (makes sense). So then I tried a CAD block with just the pline and a text box as a block, but when i save it to the library or copy and paste it from the CAD detail window onto a plan, i can only snap dimension to one side, but it looks like in a CAD detail window it snaps to both sides. I see there is a thread requesting snapping to objects in the CAD block, but this seems like a different issue. i.e. why can i snap to both sides in a CAD detail window but not in plan view? and why can i snap to the "first" side of the pline I choose? I have ended up creating a pline in my template plan in a CAD detail and having the dimensions around it, but it is a bit of a PIA to shift select, copy and try and move it, resize it to an exact location on the plan. Anyway I'm just wondering if I am missing a simpler way to do it, and if the behaviour between the CAD detail window and the plan view is "expected" Thanks 17.08.2022_16.54.12_REC CAD block with text not snappable.mp4 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 27, 2022 Share Posted August 27, 2022 Try using End to End Dimensions instead of Point to Point. Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 27, 2022 Author Share Posted August 27, 2022 yup that works, thanks. Link to comment Share on other sites More sharing options...
