reference display
BruceKC
Quite often when I'm looking at a plan, and have the reference display on, most of the referenced walls above or below show up in red as they should, but some are just simply not there at all.  I have no clue why this is happening.
XOR is a mnemonic for "Exclusive Or".  It is a logical operation with the following truth table:
True XOR True = False
True XOR False = True
False XOR True = True
False XOR False = False
True and False can represent On and Off.
In other words, If both operands are the same, the result is off (invisible in this case).
XOR in other use cases can be used to "flip" the bits in a set: True False True XOR TRUE TRUE TRUE = False True False
In this case, the second argument TRUE TRUE TRUE means flip all 3 bits.
  • Downvote 1
XOR, according to the program help:
  • XOR drawing changes the color of lines in the Reference Floor Display when they are drawn on top of lines on the Current Floor. If the lines have identical properties, they are not drawn at all. When this is unchecked, the Reference Display color does not change, and identical lines are not suppressed.
