Sill Plate Gap in X14
KilianDrafting
Go to solution Solved by rlackore,
I cannot get the exterior sheathing and siding to cover the sill plate on the foundation wall.
I skipped x13 completely and jumped to x14. The only difference I can find in x14 is in the structure tab of foundation wall spec dialog, the platform intersections includes generate between platforms but only for invisible walls and railings now. Attached is plan file if neededSill Plate Gap.plan
1 minute ago, rlackore said:
Open the Wall Type Definitions for the framed walls, select the Main Layer, and check the Material layer>Framing box.
Thank you! I knew it was some new setting I was missing. Do I have to define ALL my wall types with specific framing elements in order for framing to display correctly then?
No idea; but I've run into framing issues myself when I don't have my Walls, Floors, etc. defined properly, so my guess would be Yes.
