plotting issues
tmactom
Go to solution Solved by SusanC,
When I plot a sheet set, the elevations and cross section are skewed, This truss is off center. But in the working plan layout, it's all OK? I must have something toggled on weird as when I print to PDF it skews everything or cuts stuff...
The floor plans are fine. Just anything elevation is skewed when I go to plot it.
Any help is much appreciated!
If you search for this issue you will find that it is very common for 3 reasons:
1.) Using live views instead of plot lines as Susan mentions above.
2.) Your model is very far from the 0,0 X/Y Coordinate
3.) The terrain is very large and/or you have an item very far away from the model that is causing distortion to the view.
And one other bit of info I just learned from another post relating to Plot Line Views...  There is a button available for your toolbar called "Update All Views" and nested under that is "Update All Plot Line Views".
Always amazed at what I learn on this forum!
