MICA-HDE Posted July 8, 2022 Share Posted July 8, 2022 I followed the Youtube video on creating a simple parapet wall using the second floor method. done it before, but for some reason now the second floor (parapet walls) do not show in my renderings or sections. did I accidently turn off som01 Dleon.planething? Link to comment Share on other sites More sharing options...
Kbird1 Posted July 8, 2022 Share Posted July 8, 2022 Perhaps the Walls, Railings Layer in each view? Mick. Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 8, 2022 Share Posted July 8, 2022 24 minutes ago, MICA-HDE said: I followed the Youtube video on creating a simple parapet wall using the second floor method. done it before, but for some reason now the second floor (parapet walls) do not show in my renderings or sections. did I accidently turn off som01 Dleon.planething? Something is wrong with the attachment, are you using a floor overview camera or do you have those walls on a funny layer or is your top room/floor ceiling height set too low? Link to comment Share on other sites More sharing options...
MICA-HDE Posted July 8, 2022 Author Share Posted July 8, 2022 Wow. first time using this forum. you guys are awesome in your response time. Yes. an error came up when I tried to load the plan file. I will try a different way next time. I turned on all layers in the rendering and still nothing. I just tried pulling the floor/roof in from the edges and the railing appeared. YouTube didn't show it so I thought I didn't have to do that. Don't like the railing. I will now redo with walls and see it is better looking. Please advise if I'm doing anything wrong when creating second floor. no video shows pulling floor/roof back. Since I turned on all the layers in the camera view, what is the best way to return to my Camera View Set original state? I forget to use the All On Set sometimes.... Link to comment Share on other sites More sharing options...
Kbird1 Posted July 8, 2022 Share Posted July 8, 2022 32 minutes ago, MICA-HDE said: Since I turned on all the layers in the camera view, what is the best way to return to my Camera View Set original state? I forget to use the All On Set sometimes.... Closing the View and Reopening should do it , as it should go back to Default.... Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 8, 2022 Share Posted July 8, 2022 32 minutes ago, MICA-HDE said: floor/roof This leads me to believe you used a roof plane, which you would not need, see if you can drop a link to the YT vid and post your plan again Link to comment Share on other sites More sharing options...
MICA-HDE Posted July 8, 2022 Author Share Posted July 8, 2022 I found the same video on CA website https://www.chiefarchitect.com/videos/watch/1530/drawing-parapet-walls-with-a-flat-roof.html?playlist=95 Is there a certain way to load the plan I get an error each time. Do I need to back it up and zip it maybe? it is less than 6MB Link to comment Share on other sites More sharing options...
