Need a Ruby script to return the last character in a text string
SWBDesign
I'm trying to create a "Key to Elevations" legend using callouts which are linked to camera views which in turn will populate automatically with the last character of the camera name.
so, a camera with the name of  "Elevation A" would return the value of "A"
I need a Ruby Script which can return the last character in the variable "owner.linked_view_name"
I can get a script to return the full name of the "owner.linked_view_name" but I don't know how to parse it down to return just the last character of the returned text string.
I typically label all Elevation camera's as Elevation "A,B,C,D....etc"
Can anyone help point me in the right direction please?
On 6/30/2022 at 5:39 PM, SWBDesign said:
Sorted it.
owner.linked_view_name.slice(-1).chr
The .chr at the end is unnecessary and redundant.  The chr method will return the first character in the string; however the slice(index) method that you've used will also only return one character, so what you're essentially doing is asking for the character at the -1 index and then asking for the first character of that single character string.
I think the most elegant method is the one Eric showed though. Slice works, but simply calling for the index inside brackets is cleaner.
