Conservation Orangery
Jackstacey
Go to solution Solved by Chopsaw,
Good Morning,
I need to create a roof lantern / skylight which has similar properties to this. It is for a Grade 2 listed build which is applying for an Orangery on the side of the property.
Sky lights are a flat unit which doesn't show the Pyramid shape as well as the frame/lead work between the panels. Any help is appreciated.
  • Solution
I think I would just do my best to attempt to work with the layers of a roof plane to do that.  Obviously no tiles or shingles and replace the sheathing with glass. Modify rafter size, spacing  and material to look like frame/lead work. And possibly a few extra moldings or p-solids where the roof planes fall short.  Good Luck !
