5FT-20Designs Posted June 20, 2022 Share Posted June 20, 2022 When I pull a dimension from the bottom of the microwave to the top of the oven, the dimension isn't showing. Still shows the drag handles foir the dims. Seems to be an issue with my microwave (Mfr JennAir) since the oven deminsions correctly. Thanks, Keith Link to comment Share on other sites More sharing options...
5FT-20Designs Posted June 21, 2022 Author Share Posted June 21, 2022 Eric, When i zipped the file it was larger than 14mb. I'll narrow the drawing down to just the wall and submit. Link to comment Share on other sites More sharing options...
5FT-20Designs Posted June 21, 2022 Author Share Posted June 21, 2022 Attached is the reduced plan. Keith Dimension Issue.zip Link to comment Share on other sites More sharing options...
Solution robdyck Posted June 21, 2022 Solution Share Posted June 21, 2022 Open a dimension and check this box: 1 Link to comment Share on other sites More sharing options...
5FT-20Designs Posted June 21, 2022 Author Share Posted June 21, 2022 Robert, Thank you for the help. 1 Link to comment Share on other sites More sharing options...
robdyck Posted June 21, 2022 Share Posted June 21, 2022 1 hour ago, 5FT-20Designs said: Robert, Thank you for the help. Your welcome Keith! Link to comment Share on other sites More sharing options...
