RL-inc Posted June 15, 2022 Share Posted June 15, 2022 I have been banging away on trying to come up with a new kitchen design for a remodel project and this one has me over a barrel. In the attached screenshot I have clouded the area I have to work with - all existing walls that need to go have been removed and I have left the bearing walls and point loads that need to stay. I want to get a kitchen with a pantry that will be open to the dining area and capture the views. I also need a powder bath and / or bath 2 for bed 2- can be one or 2 rooms depending. If anyone is interested at taking a swing at it, I am not hoping for a full design by any means- just a general layout idea that may kick me in a different direction than where I keep stonewalling at. (I have pics of existing I can share but don't want to create any undue influence - I think that is a major issue I am having.) STEFFEN REMODEL 1ST IDEA- blank.plan STEFFEN REMODEL 1ST IDEA- blank.plan Link to comment Share on other sites More sharing options...
SteveNovato Posted June 15, 2022 Share Posted June 15, 2022 Rob, There are so many variables here. It looks like a tough layout because of the angled wall and 'bump out'. I would guess that the bathroom door would open to the hall?? I usually start with the type/size of appliances the customer wants and place the sink, range and refer (then fill in from there). Sometimes, putting too much in a plan makes everything function poorly. If you are not pleased with the outcome on paper, you will not like the final result either. I know this is not what you requested...just my 2 cents worth on getting started. Steve Link to comment Share on other sites More sharing options...
RADHomes Posted June 16, 2022 Share Posted June 16, 2022 Without knowing anything else and the variables this is where I might start, (it's rough and it was quick) range could be moved, more stools, larger bathroom if need... 1 1 Link to comment Share on other sites More sharing options...
RL-inc Posted June 17, 2022 Author Share Posted June 17, 2022 Thanks Ryan- Just what I was looking for- different direction than I was headed with the pantry. I'll play with it and post whatever I come up with. much appreciated . Link to comment Share on other sites More sharing options...
