capitaldesigns Posted June 11, 2022 Share Posted June 11, 2022 I am inputting a floor plan of a house that I measured today. The house is a rectangle with raised foundation. Simple. The front of the house has a masonry fireplace on the exterior wall. I used Chiefs fireplace tool to place the fireplace. This is causing a problem with placing the raised foundation. Chief will draw the footings for the back of the house but is missing all of the footings in the front of the house where the fireplace is placed. Does anyone know why Chief is not drawing the footings in the room where there is a fireplace ? I have attached the drawing. Thank You, Mike Newstrom As-Built Plan.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 11, 2022 Share Posted June 11, 2022 "Why" is a good question for Tech Support. If it were me I would just manually draw in the missing foundation walls and then just drive on. That is my advice. DJP Link to comment Share on other sites More sharing options...
capitaldesigns Posted June 11, 2022 Author Share Posted June 11, 2022 Thank you for putting together the video. Originally I did not draw the invisible walls through the fireplace footing. When I did that half of the foundation was missing. I tried the invisible walls to see if the would work and Chief would draw the whole foundation. That did not work. Your solution worked. Thank You, Mike Link to comment Share on other sites More sharing options...
