junior Posted June 6, 2022 Share Posted June 6, 2022 Using X14 When I add the story pole dimensions to the cross section elevation view ,then covert the view to a cad detail from view, the story pole dimensions change. Example, The dimension on the story pole dimension at the sub-floor level is 0' in the cross section view. When converted to a cad detail from view, the dimension changes to 11'- 2 1/4". Also on X14 I can't edit the story pole text or move the text in the cad from detail view. Not the case in previous versions. Link to comment Share on other sites More sharing options...
robdyck Posted June 6, 2022 Share Posted June 6, 2022 9 minutes ago, junior said: Using X14 When I add the story pole dimensions to the cross section elevation view ,then covert the view to a cad detail from view, the story pole dimensions change. Example, The dimension on the story pole dimension at the sub-floor level is 0' in the cross section view. When converted to a cad detail from view, the dimension changes to 11'- 2 1/4". Also on X14 I can't edit the story pole text or move the text in the cad from detail view. Not the case in previous versions. Don't convert it to a CAD detail; keep it live. 1 Link to comment Share on other sites More sharing options...
