wkshank Posted May 20, 2022 Share Posted May 20, 2022 Normally, if I create a simple rectangle and then right click it, the menu that appears will include a zigzag symbol that allows me to add a break in the polyline. Or if I simply select the rectangle, a menu appears at the bottom also offering that symbol. The symbol has disappeared, in both lists. I searched for that tool in the menu and don't see it. Help? It appears and works fine if I click on a roof edge (add break option appears). Link to comment Share on other sites More sharing options...
rgardner Posted May 20, 2022 Share Posted May 20, 2022 Hint oob the 3 key is the break tool. 1 Link to comment Share on other sites More sharing options...
wkshank Posted May 20, 2022 Author Share Posted May 20, 2022 Yep - it's there (works fine) if I start a new plan. rgardner I'm trying to decipher your hint. ? Link to comment Share on other sites More sharing options...
wkshank Posted May 20, 2022 Author Share Posted May 20, 2022 Saved, closed, and re-opened the plan and it still is not there. Link to comment Share on other sites More sharing options...
rgardner Posted May 20, 2022 Share Posted May 20, 2022 15 minutes ago, wkshank said: rgardner I'm trying to decipher your hint. ? 21 minutes ago, rgardner said: Hint oob the 3 key is the break tool. Out of Box (common acronym used on here) the #3 key is the keyboard shortcut for the break tool that you are looking for. Link to comment Share on other sites More sharing options...
Dermot Posted May 20, 2022 Share Posted May 20, 2022 Did you maybe draw a box instead of a polyline? Hint, if you select an object the program will tell you what type of object it is in the status bar. A CAD Box might look a lot like a Standard Polyline but it can't be broken. 1 Link to comment Share on other sites More sharing options...
wkshank Posted May 20, 2022 Author Share Posted May 20, 2022 Both of you have my thanks... now I know oob, the 3 shortcut, AND that boxes look JUST like rectangle polylines, and cannot be broken. Sheesh. Grateful - Link to comment Share on other sites More sharing options...
