Alfiejay08 Posted May 15, 2022 Share Posted May 15, 2022 I love lighting in rooms, so I tend to make (or update from other models) a lot of lights. I notice that once I import them into my library as a symbol, the lights no longer light (see attached). What am I doing wrong? Can someone please explain the correct way to add a light fixture to your library? thanks, Alfie Link to comment Share on other sites More sharing options...
MarkMc Posted May 15, 2022 Share Posted May 15, 2022 Used first SU file I could dig up on mine, bit of fun as it turns out. Importing or creating light symbol. First select as Electric and always Advanced Options; then Options Panel-check light for a chandelier or my cave light select ceiling I find it useful to rename parts of symbols so I can understand what it is in the future, at the same time change the materials to standard library materials. To make renaming parts simpler I start by selecting an obvious color for the item, like berry, rename it, select correct material and move to next. It's a good idea to double check the Name and check the Origin and orientation at this time (look in help for symbols) In this case the object was flipped vertically and origin set to 0 so it would be on ceiling. Then click OK and item should now be in your library and already selected for placement. IF you selected Electric, and Light at the beginning there should be a light data panel with one light already in place. To make changes here please check the help or user manual PDF. Finish light in room with the default single light in it. I kinda like it, wonder if I can get one (oh and forgot- please fill out your signature with software version and machine info since that can help in the future- there's info floating around for that and likely someone will chime in) 1 Link to comment Share on other sites More sharing options...
Alfiejay08 Posted May 16, 2022 Author Share Posted May 16, 2022 Thank you so much MarkMc! I would love to send you a copy. I'm sorry, I have been down and out with Covid for awhile, so I haven't had a chance to update anything. But I will add that information as soon as possible. In fact, this is the first week in some time that I have felt able to really breath. Thank you again, and I will add that file when I get back home today. Link to comment Share on other sites More sharing options...
Alfiejay08 Posted May 19, 2022 Author Share Posted May 19, 2022 Here is the file for that Light. It is not my design, I only updated it. I got if from 3D Warehouse. Thank you everyone for your help. Chandelier with Shades Bronze & Candles.skp Link to comment Share on other sites More sharing options...
MarkMc Posted May 19, 2022 Share Posted May 19, 2022 Follow the directions given above and let us know how you did. 1 Link to comment Share on other sites More sharing options...
Alfiejay08 Posted June 5, 2022 Author Share Posted June 5, 2022 On 5/19/2022 at 8:00 AM, MarkMc said: Follow the directions given above and let us know how you did. MarkMc you are AWESOME! Since I followed your directions, I LOVE putting light into fixtures I find online. They are so beautiful now! This is the latest one that I found on SketchUp. THANK YOU SO MUCH! 1 Link to comment Share on other sites More sharing options...
Rich_Winsor Posted June 5, 2022 Share Posted June 5, 2022 Very nice indeed. +1 Link to comment Share on other sites More sharing options...
Kaverony Posted September 4 Share Posted September 4 (edited) That happens if the light isn’t set up as a true light object before turning it into a symbol. I ran into it once while updating some fixtures and ended up just making sure the light properties carried over before saving. Some of the designs on Seus lighting gave me ideas for keeping the glow realistic. After tweaking that, all my imported lights worked and even matched the mood I wanted for different rooms. Edited Wednesday at 11:51 AM by Kaverony Link to comment Share on other sites More sharing options...
