alenal Posted May 4, 2022 Share Posted May 4, 2022 Hello, I need helo figuring out how I can create an angled island in chief architect. Link to comment Share on other sites More sharing options...
MarkMc Posted May 4, 2022 Share Posted May 4, 2022 You can't just make a cabinet like that in Chief. Easiest is to use a solid shown below. Can make that into an open box using boolean subtraction after making a second solid. (look in help) Can make an open front with using an angle front wall cabinet and converting to a symbol which you then rotate in the advanced options when making it. Could also make it with panels. IF you want a door need to make a custom door symbol and float it in. X13 plan attached. Please add a signature with version and hardware- instructions are posted around here somewhere. Angled options.zip 2 Link to comment Share on other sites More sharing options...
Kenoeightspot Posted May 6, 2022 Share Posted May 6, 2022 Knife edge counter top. Model separate. 1 Link to comment Share on other sites More sharing options...
