Please help - Angled Island
alenal
You can't just make a cabinet like that in Chief.
Easiest is to use a solid shown below. Can make that into an open box using boolean subtraction after making a second solid. (look in help)
Can make an open front with using an angle front wall cabinet and converting to a symbol which you then rotate in the advanced options when making it.
Could also make it with panels. IF you want a door need to make a custom door symbol and float it in. X13 plan attached. Please add a signature with version and hardware- instructions are posted around here somewhere.
Angled options.zipFetching info...
  • Upvote 2
