bdillard1 Posted February 24, 2022 Share Posted February 24, 2022 Hello, I imported this nice symbol for a shower - https://3dwarehouse.sketchup.com/model/1d41e5de2d0d62249ab765831d580703/shower Unfortunately, while I can modify the height of the symbol, I'd like a slim window over the shower so I can only go so far. I'd like to move or delete the shower head but using delete surface (the way I'm trying to) is quite a chore as you have to delete every single item - e.g. shower water hole one by one. Is there a way to select an area when deleting surfaces or can I some how move the shower head up about a foot? Link to comment Share on other sites More sharing options...
Chopsaw Posted February 24, 2022 Share Posted February 24, 2022 If you experiment with changing the "Smoothing Angle" of the symbol it can allow you to more efficiently delete surfaces to create a modified symbol. If you want to do something like move an embedded shower head then you need to delete every single surface with the exception of the shower head and create an independent symbol from it so it can be positioned any where you like. Apparently if you have the time to learn another program, Sketchup has some more efficient tools for editing their symbols. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted February 24, 2022 Share Posted February 24, 2022 1 hour ago, bdillard1 said: Hello, I imported this nice symbol for a shower - https://3dwarehouse.sketchup.com/model/1d41e5de2d0d62249ab765831d580703/shower Unfortunately, while I can modify the height of the symbol, I'd like a slim window over the shower so I can only go so far. I'd like to move or delete the shower head but using delete surface (the way I'm trying to) is quite a chore as you have to delete every single item - e.g. shower water hole one by one. Is there a way to select an area when deleting surfaces or can I some how move the shower head up about a foot? This particular symbol really should not be used. You will run into way too many problems trying to conform it. Also, this question should be in General Q&A. This forum is for sharing symbols really. FYI we can build a shower like this in under a minute with the right know-how and have it be dynamic, schedule reporting, parametric and more when you learn the tools that we have. For other symbols that need modification, chopsaw gave a great solution. 1 Link to comment Share on other sites More sharing options...
