3D Chief Architect Designs, Training, Coaching
Member Statistics
Similar Content
By KO1413
Hi there
I'm pretty new to Chief Architect and I have a project with a pretty bizarre roof line. I'm SO close to connecting everything but I'm not sure how to have a roof slope in two different directions. I've attached images of the section of roof I'm interested in fixing (if it's possible). It's a triangle that connects to other roof sections at two of three corners. However, one corner sits high because that section needs to slope in two directions. I was hoping there was a way to select the two corners and simply join them and have the program figure out the slope needed for this but I can't seem to figure this out on my own. Anyone have any tips/tricks/advice?
Below is a OneDrive link to the .plan file I am working on:
https://1drv.ms/u/s!AjJMbQMG7iV1gsch39gBGIlQ9B519Q
I am using Chief Architect X14.
Thanks in advance
Kristy
By Elopez
Hello, I'm new to chief architect and I'm trying to use this sink that I wants in my model but is not in the library so I have to download it from the website. But when I do it comes out in 2D and the 3D one doesn't come out like I want. I have downloaded the sink in drawing DWG, OBJ and I don't know what to do. The pictures at the bottom are the sink and what I get when downloaded. sink
DWG
OBJ
By Danielle_AZL
Hello,
I have come across a lot of matterport ads, but it does not seem to work well with CA without a lot of converting of files. What do other CA users use that is an alternative to matterport?
By kerhansen
Now that you've registered for Chief Academy, get tips to prepare for getting the most out of your experience!
How to Prepare for Chief Academy
