Angle - Degree By Default?
simonas
My angular dimensions have Minutes + Seconds as default Angle Style (not sure what is it) I would like to see degrees as default angle style is it possible to do so? and also I have 6 numbers after dot, can I make it to 2? Please see screenshots attached:
Here I have 61.369465, how do you make 61.36 ???
you are right ,when I open the degree dimension DBX it always seems to have Minutes+ seconds checked even though it is showing Degrees in the Defaults , so I guess I can't help much :(   since you need to change it to degrees manually by checking the radio button, I hadn't noticed as I have angle snaps on so don't get those crazy decimal/minute+second numbers showing automatically.
did you open the number style dialog and check it there too?
