bdillard Posted January 21, 2022 Share Posted January 21, 2022 Hello, I'd try to make my house much more quiet. I've seen a number of videos and there are levels of sound insulation. For the most part I'll just be putting mineral wool in the walls. When I try to modify them - it makes the walls thicker as I don't know how to add it as a bat or between stud insulation. Instead of 4 1/2" walls they become 8". I'm sure it is obvious but I haven't figured it out - if it matters I'm using X12. Link to comment Share on other sites More sharing options...
Solution Chopsaw Posted January 21, 2022 Solution Share Posted January 21, 2022 Don't make a new layer unless that is how it is actually going to be designed with a thicker wall. Normally just put a checkmark in the "Ins" column of the main layer. If you want to show it in 3D you will need to put it in manually. 1 Link to comment Share on other sites More sharing options...
bdillard Posted January 21, 2022 Author Share Posted January 21, 2022 Thanks for your response! Link to comment Share on other sites More sharing options...
