Designer1 Posted January 18, 2022 Share Posted January 18, 2022 I was watching training videos on some of the new features on Chiefs X13 stair tool... thank you chief there are a lot of stair improvements! I was trying to see if using the new U stair tool can make a certain stair that I was looking for. The stair I wanted to create using the U stair tool is the one on the bottom I created manually. The three on the top were the only ones I was able to create using the U tool. For some reason the 3rd stair is the closest I could come but when you open that stair DBX it doesnt acknowledge the middle step in the landing as another stair so you cant customize the size. I finally gave up and figured Id post the question here because I dont know if I can get this result from the U tool. Thanks in advance! Link to comment Share on other sites More sharing options...
Designer1 Posted January 18, 2022 Author Share Posted January 18, 2022 Hi Eric, thanks for the reply and reading recommendations. The posts talk about the issue in X12... do you know if any changes have been made in X13 to fix this? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 18, 2022 Share Posted January 18, 2022 There were no changes in X13 for stairs. I have no idea what might be coming in X14. Currently the only way to create a true "Wide-U" (3 flights) is to manually create 3 single flights and connect them with 2 landings. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 18, 2022 Share Posted January 18, 2022 2 hours ago, solver said: Chief clearly does not see this as being broken, so there is nothing to fix. Really? Maybe they don't see it as being "broken", but that doesn't mean it shouldn't be modified (fixed) so that it works the way we need it to. Link to comment Share on other sites More sharing options...
Designer1 Posted January 19, 2022 Author Share Posted January 19, 2022 14 hours ago, Joe_Carrick said: Really? Maybe they don't see it as being "broken", but that doesn't mean it shouldn't be modified (fixed) so that it works the way we need it to. Joe I agree with you 100% and thank you for letting me know. Link to comment Share on other sites More sharing options...
Designer1 Posted January 20, 2022 Author Share Posted January 20, 2022 Another item I couldnt find using the L and U auto stair tool is customizing the width of the stair? Like in the dbx where it asks about clockwise, split landing etc it would be nice to allow for width resizing. Im guessing the only way to change this would be through stair defaults but then it would change all your stairs moving forward. This would be a nice added feature besides the one talked about above for the stair dbx. If there is a way to change the width of a stair using the auto tools please let me know. Thanks! Link to comment Share on other sites More sharing options...
