TxHillbilly Posted January 3, 2022 Share Posted January 3, 2022 I'm a former Autodesk user and new to CA. I'm putting together a small lodge for a friend. I've been struggling with the details. Right now I am looking at a cross-section and found that the stone veneer is resting on nothing! I've been tinkering with settings for a while to no avail. Can someone smarter than me point out what I've done wrong? I tried attaching the file but it is over the allotted file size. Link to comment Share on other sites More sharing options...
TxHillbilly Posted January 3, 2022 Author Share Posted January 3, 2022 4 minutes ago, solver said: All someone needs is the basic structure. You might delete everything else. Did you try zipping? Are you expecting to see a brick ledge for your stone to sit on? Did you use a Brick wall and then change the brick material to stone? Please check your messages -- envelope icon top of page. My apologies, I'm using X13. I forgot about zipping so it is now attached. Yes, I used the brick veneer but changed it to stone. The question is spot on too because now I need to find out if the owner plans to use stone or the less expensive fake veneer which is nailed to a sheathing. For what it's worth, I appreciate the help and feedback. Lodge.zip Link to comment Share on other sites More sharing options...
TxHillbilly Posted January 3, 2022 Author Share Posted January 3, 2022 SOLVER: Thanks for the info. Yes, I asked the question first and then added some info to my profile, apparently they crossed paths during the response you provided. I've read so many helpful things that you've provided to others so let me thank you as well. Link to comment Share on other sites More sharing options...
Michael_Gia Posted January 4, 2022 Share Posted January 4, 2022 Why isn’t Solver moderator already? Or maybe make filling out the part about what version you have as mandatory when creating an account? Or automatically tagged on by Chief? Link to comment Share on other sites More sharing options...
TxHillbilly Posted January 4, 2022 Author Share Posted January 4, 2022 Ok, I had some time to tinker with the Brick Ledge Depth. It was set to 12". Nothing changed by changing this variable to any other number, including 0. Maybe there is another variable that can be adjusted? Maybe I've got a wall defined wrong? Regardless, any help is certainly appreciated. Link to comment Share on other sites More sharing options...
robdyck Posted January 4, 2022 Share Posted January 4, 2022 11 hours ago, TxHillbilly said: Nothing changed by changing this variable to any other number, including 0 The CAD detailing does NOT auto-update. Create a new section view, then click "Auto Detail" to see the difference. NOTE to CHIEF ARCHITECT: PLEASE remove the auto brick ledge depth created by masonry materials! Link to comment Share on other sites More sharing options...
