Decorationarts Posted December 11, 2021 Share Posted December 11, 2021 Does anyone have a A "Slat Wood Wall Panel" or "Acoustic Slat Wood Wall Panel? Link to comment Share on other sites More sharing options...
Kbird1 Posted December 11, 2021 Share Posted December 11, 2021 On 12/11/2021 at 11:26 AM, Decorationarts said: Does anyone have a A "Slat Wood Wall Panel" or "Acoustic Slat Wood Wall Panel? Just use the Frame 3 1/2 walltype , copy the definition and make it 1 1/2 thick instead.... and add a layer of Black behind if you need it... Try this.....MHD_Slat Wall Wall Type.calibz The Framing on Building will follow whatever the current Framing is for top and Bottom Plates so you may need to alter that to get the exact look you need. Mick. 2 Link to comment Share on other sites More sharing options...
Decorationarts Posted December 15, 2021 Author Share Posted December 15, 2021 Nice, Good Idea Link to comment Share on other sites More sharing options...
GregoryStorm Posted September 8, 2022 Share Posted September 8, 2022 On 12/11/2021 at 1:48 PM, Kbird1 said: Just use the Frame 3 1/2 walltype , copy the definition and make it 1 1/2 thick instead.... and add a layer of Black behind if you need it... Try this.....MHD_Slat Wall Wall Type.calibz Hi Kbird1 this solution does not seem to work in X14. Any idea why it doesn't work? Link to comment Share on other sites More sharing options...
glennw Posted September 8, 2022 Share Posted September 8, 2022 Have you built the wall framing? Link to comment Share on other sites More sharing options...
Kbird1 Posted September 8, 2022 Share Posted September 8, 2022 14 hours ago, GregoryStorm said: Hi Kbird1 this solution does not seem to work in X14. Any idea why it doesn't work? Did Glen's Advice help you out? that would of been my 1st guess the 2nd being you don't have wall framing turned on in the Camera View. *Update...seems to still work fine in a quick test plan >>>>>>>>>>>>>>>>>> Slat Wall Test.plan Mick. Link to comment Share on other sites More sharing options...
GregoryStorm Posted September 10, 2022 Share Posted September 10, 2022 On 9/7/2022 at 10:47 PM, glennw said: Have you built the wall framing? On 9/8/2022 at 11:11 AM, Kbird1 said: Did Glen's Advice help you out? that would of been my 1st guess the 2nd being you don't have wall framing turned on in the Camera View. *Update...seems to still work fine in a quick test plan >>>>>>>>>>>>>>>>>> Slat Wall Test.plan Mick. Ah. Turning on Framing, Wall Active Layer allowed me to see the wood slats in Vector View but Standard and Physically Based (Ray Trace) showed one flat wall with no wood slats until I hit the Build Framing For Selected Object(s) button. I didn't know that was a need step for this to work. Thanks for the help. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 10, 2022 Share Posted September 10, 2022 3 hours ago, GregoryStorm said: Ah. Turning on Framing, Wall Active Layer allowed me to see the wood slats in Vector View but Standard and Physically Based (Ray Trace) showed one flat wall with no wood slats until I hit the Build Framing For Selected Object(s) button. I didn't know that was a need step for this to work. Thanks for the help. If you don't need the black "shadow" behind the 2x2 Slats , just delete the black layer from the Wall Definition. Mick. Link to comment Share on other sites More sharing options...
