Removing Soffits
MaryAnne2017
It helps to post a picture of what you are seeing.  It also helps to add the program version to you signature because some things won't be the same in all versions.
If your soffit is against the ceiling but it is not bumped up against a wall, deleting it will not automatically fill the hole the way it should.  All you need to do is rebuild floors/ceilings (F12) to fix this.  Lot's of other things will automatically rebuild your floors and ceilings so this problem is pretty well hidden.  Regardless, when you run into problems like this, feel free to report them to our tech support team.
