SCraig Posted November 30, 2021 Share Posted November 30, 2021 Is it possible to select two rooms for one schedule? I understand I can select the whole floor, but can I choose two rooms? Link to comment Share on other sites More sharing options...
Chopsaw Posted November 30, 2021 Share Posted November 30, 2021 Yes there are preset categories for room type which most likely can work for you or if not you may need custom categories. Link to comment Share on other sites More sharing options...
SCraig Posted December 1, 2021 Author Share Posted December 1, 2021 Ok, thank you - I see the pre-set categories for room types, although I'd like to take cabinet C60 that is in the kitchen and remove from the kitchen schedule and place it in the dining room schedule that I have created. It's a different material from the kitchen and so It's on a different order and numbered according to the Dining Room schedule, not the kitchen schedule. The drop-down menu only allows me to select the room that the cabinet is placed in, so therefore it is going into the kitchen schedule. Am I making any sense? Link to comment Share on other sites More sharing options...
Dermot Posted December 1, 2021 Share Posted December 1, 2021 See if this tech article helps: https://www.chiefarchitect.com/support/article/KB-03120/creating-custom-schedules.html Link to comment Share on other sites More sharing options...
SCraig Posted December 2, 2021 Author Share Posted December 2, 2021 Dermot, Thank you! Article was helpful and I now have two schedules with the correct cabinets in each one! Link to comment Share on other sites More sharing options...
